A new update is available for BMI Calculator by XenCustomize.
Version 2.3.1 is for XenForo 2.3.x only!
Thank you for your continued support. If you're enjoying BMI Calculator, we'd greatly appreciate a rating on XenForo.
Calculator form with Metric/US units, Result box, BMI categories table
XenCustomize BMI Calculator v2.3.1 Released
Version 2.3.1 is for XenForo 2.3.x only!Thank you for your continued support. If you're enjoying BMI Calculator, we'd greatly appreciate a rating on XenForo.
New Featured & Improvements
- Added Metric units / US unitssupport to the BMI calculator.
- Members can now calculate BMI using kg/cm or lb/ft/in.
- This makes the calculator easier to use for both international and US-based communities.
- Added smart pre-fill for returning members.
- If a member already has a BMI record, the calculator now loads their latest values automatically.
- Members can create a new entry faster by changing only what is different.
- Improved BMI calculation accuracy and consistency when saving new records.
- Strengthened permission and ownership checks around saving, editing, and deleting BMI records.
- The new unit switcher blends into the existing calculator design for a clean, familiar experience.
- Added XenCustomize Core Library v1.0.1 as a required dependency.
- Added license key setup through the add-on options License options tab.
- Added optional branding-free license key support where applicable.
